I am looking for a help in building an iApp template with Single VIP IP attached with iRule with Dev, Prod and QA pools based on URL redirection. Example
ABC1.abc.com → Single VIP IP with dev, QA and Prod pools ABC2.abc.com → Single VIP IP with dev, QA and Prod pools ABC3.abc.com → Single VIP IP with dev, QA and Prod pools
using standard profiles http and wildcard certificate profile.
Can this be possible? any init direction is appreciated..
Multiple pools are handled from 1 virtual using an irule in the f5.microsoft_exchange_2013_cas iApp. If you want to use that code for reference, look for “combined_pool_irule”.
