We have a pair of 6900s in an HA configuration with fully licensed APM and LTM. I want to use the f5.vmware_view.v1.5.0rc1 iApp for Horizon view. It loads fine but omits the whole section on smartcard authentication in the APM section of the accompanying deployment guide. This is a critical feature that we need for this implementation. The rest of the APM questions appear as they do in the guide. How can I get the iApp to show this section?
Forgot to mention we are using code 11.6.1.
Smartcard support requires a minimum version of 12.0. The iapp detects the TMOS version running on entry and will only display the Smartcard options when v12.0 or higher.
Thank you for the clarification.
