Hi there,
I’m trying to write a Perl iControl client to manage the creation/amendment of iApp application services on our v11 F5’s…
Currently, I’ve got the following script:
!/usr/bin/perl
use Getopt::Long;
use Switch;
use SOAP::Lite;
use MIME::Base64;
use Math::BigInt;
use Data::Dumper;
use FindBin;
use lib "$FindBin::Bin/../lib";
use iControlTypeCast;
Disable SSL Certificate Verification
$ENV{PERL_LWP_SSL_VERIFY_HOSTNAME}=0;
Validate Arguments
Define varaibles
my ($sHost, $sPort, $sUID, $sPWD, $sMode, $action, $filename );
Pickup Run-Time Options
GetOptions (
"sHost=s" => \$sHost,
"sPort:i" => \$sPort,
"sUID=s" => \$sUID,
"sPWD=s" => \$sPWD,
"$sMode:s" => \$sMode,
"action:s" => \$action,
"filename:s" => \$filename
Assume always HTTPS
my $sProtocol = "https";
if ( ("80" eq $sPort) or ("8080" eq $sPort) )
$sProtocol = "http";
if ( ($sHost eq "") or ($sPort eq "") or ($sUID eq "") or ($sPWD eq "") )
&usage();
sub usage()
my ($sCmd) = @_;
print "Usage: CertInfo.pl --sHost host --sPort port --sUID username --sPWD password --action [script action] \n";
exit();
Transport Information
sub SOAP::Transport::HTTP::Client::get_basic_credentials
return "$sUID" => "$sPWD";
$AppServiceHandler = SOAP::Lite
-> uri('urn:iControl:Management/ApplicationService')
-> proxy("$sProtocol://$sHost:$sPort/iControl/iControlPortal.cgi");
eval { $Pool->transport->http_request->header
'Authorization' =>
'Basic ' . MIME::Base64::encode("$sUID:$sPWD", '')
Action Code
switch ($action) {
case 'ci' { &GetCertInfo($sMode) }
case 'im' { &ImportCert($mode, $filename) }
case 'ial' { &GetiAppList }
else { print "Specified check not found ($action) \n" }
sub GetiAppList()
$soapResponse = $AppServiceHandler->get_list ();
&checkResponse($soapResponse);
@AppListA = @{$soapResponse->result};
print "Received Application Services list";
print Dumper(@AppListA);
foreach $AppList (@AppListA)
print "Application Service...";
checkResponse
sub checkResponse()
my ($soapResponse) = (@_);
if ( $soapResponse->fault )
print $soapResponse->faultcode, " ", $soapResponse->faultstring, "\n";
exit();
However all i’m getting printed out is:
D:\Workspace\F5_iControl>perl bin/f5_icontrol.pl --sHost f501 --sPort 443 --sUID xxx --sPWD xxx --a
ction ial
Any ideas where I’m going wrong?
Cheers
Gavin
