iapp help with pool creation for fqdn autopopulate enabled
I am needing some help with iapp syntax to make sure the newly created pool is created with fqdn & autopopulate enabled. I am using the default http iapp, the newly created pool is created correctly; however, autopopulate for the pool is disabled. How can I set the pool to always be created with fqdn & autopopulate enabled when it creates the new pool as the iapp will only be used for a FQDN node. I would think I would set it somewhere below, just not sure how.
1,0 { [iapp::conf create ltm pool ${app}_pool \ [iapp::substa pool_ramp_pga_arr($advanced,$do_slow_ramp,$do_pga)] \ [iapp::substa pool_lb_queue_arr($advanced,$lb_lcm_licensed,$tcp_queuing)] \ [iapp::substa monitor_arr($new_pool,$new_monitor,$advanced)] \ [iapp::pool_members $::pool__members]] \ translate-address enabled } 0,0 { [expr { $::net__server_mode ne “tunnel” ? \ $::pool__pool_to_use : $::pool__pool_to_use_wom }] \ translate-address enabled } * { none translate-address disabled } }
So, this was quite the challenge; I spent some time looking into how to accomplish this task, and it’s not straight-forward.
The command used to generate the pool members syntax is:
in the
Implementation
section of the iApp.
pool__members
is a table generated by the
Presentation
iapp::pool_members
is a tcl procedure (similar to a python function) called from the
iapp 1.0.3
package.
The
iapp::pool_members
procedure is written in a way that does not account for the syntax required to add
fqdn { autopopulate enabled }
So this solution requires modifying several steps:
  1. Update the presentation template to include an ‘autopopulate’ option.
  2. Update Update the iapp utility package to read the variable created by autopopulate and write-out the appropriate pool member syntax.
Let’s Begin
  1. Copy the Presentation, Implementation and HTML Help templates from the default iApp to your favorite text editor:
    TMUI → iApps → Templates →
  2. Update the Presentation Template in the following ways:
    a. Update the pool members table and add
    choice autopopulate
        table members {
            optional (( ssl_encryption_questions.legacy_advanced == "yes"
                    || ssl_encryption_questions.advanced == "yes" )
                    && use_pga == "yes" ) {
                string priority default "0" required
                    validator "NonNegativeNumber" display "small"
            choice autopopulate                  <<<--------< Add this line
        optional ( ssl_encryption_questions.help == "max" ) {
            message members_max
    b. In the ‘Text’ section, add
    pool.members.autopopulate
    section which will provide a ‘None, Yes, No’ set of options in TMUI when creating the pool member(s).
        pool.members.port_secure "Port"
        pool.members.autopopulate "Autopopulate" {       <<<--------< Add these lines
            "None" => "",                                <<<--------< Add these lines
            "Yes"  => "enabled",                         <<<--------< Add these lines
            "No"   => "disabled"                         <<<--------< Add these lines
        }                                                <<<--------< Add these lines
        pool.members.connection_limit "Connection limit"
  3. Remount /usr as Read-Write (rw) so we can make changes.
    mount -o remount,rw /usr
  4. Create a copy of the iapp.1.3.0.tcl package so we can customize it without modifying the original:
    cp /usr/share/tcl8.5/iapp/iapp.1.3.0.tcl /usr/share/tcl8.5/iapp/iapp.1.3.0.1.tcl
  5. Update the new package so it knows it provides iapp 1.3.0.1 package.
    sed -i 's/package provide iapp 1.3.0/package provide iapp 1.3.0.1/g' /usr/share/tcl8.5/iapp/iapp.1.3.0.1.tcl
  6. Tell scriptd that the new package exists by adding an entry to /usr/share/tcl8.5/iapp/pkgIndex.tcl
    echo 'package ifneeded iapp 1.3.0.1 [list source [file join $dir iapp.1.3.0.1.tcl]]' >> /usr/share/tcl8.5/iapp/pkgIndex.tcl
  7. Change to /usr/share/compat-tcl8.4/iapp/ directory and add a new symlink:
    cd /usr/share/compat-tcl8.4/iapp/
     ln -s  /usr/share/tcl8.5/iapp/iapp.1.3.0.1.tcl iapp.1.3.0.1.tcl
  8. Edit /usr/share/tcl8.5/iapp/iapp.1.3.0.1.tcl to account for the new
    property (Step 2):
    vim /usr/share/tcl8.5/iapp/iapp.1.3.0.1.tcl
    a. Add
    fqdn  autopopulate
    to the
    fields
    array:
    proc ::iapp::pool_members { args } {
         Set defaults.
        array set fields {
            address          addr
            port             port
            port-secure      port_secure
            connection-limit connection_limit
            priority-group   priority
            ratio            ratio
            fqdn             autopopulate   <<<--------< Add this line
    b. Update this foreach loop:
                 Transfer non-port fields from the table to the tmsh string.
                foreach name $nonport_fields {
                    if { [info exists columns($fields($name))] } {
                        append members " $name $columns($fields($name))"
    TO:
                        if { $name == "fqdn" } {
                            if { $columns($fields($name)) != "" } {
                                append members " fqdn \{ autopopulate $columns($fields($name)) \}"
  9. Exit the text editor (:wq) and remount /usr as Read-Only (ro)
    mount -o remount,ro /usr
  10. In the Presentation Template and Implementation Template, make the following changes:
    NOTE: There are over 50 references; make sure you get them all; I suggest a search/replace function in your text editor.
        package require iapp 1.3.0
    TO:
        package require iapp 1.3.0.1
  11. Create a new, custom iApp Template using the modified Implementation and Presentation templates and the unmodified HTML Help section:
    • TMUI → iApps → Templates → Templates →
      click
      ‘Create’
    • Provide a name for your new template.
    • Minimum BIG-IP Version == 11.5.0
    • Copy the ‘Implementation Template’,
      Modified
      ‘Presentation Template’, and ‘HTML Help’ section into the appropriate
    • Click ‘save’
  12. Deploy a new iApp using the customized template.
    TMUI → iApps → Application Services → Applications →
    click
    ‘Create’
    NOTE: The FQDN ‘ltm node’ object must have already been created with ‘fqdn { autopopulate enabled }’, otherwise you will observe the following error:
    01070734:3: Configuration error: Cannot enable pool member to autopopulate: node (/Common/example.com) has autopopulate set to disabled.
Jason,
My apologies for just now responding to your response on Oct 26th.  After I posted my additional questions on Oct 16th, I ended up opening an F5 support case due to business & project pressures and worked with that F5 engineer who was in touch with development for well over a week looking for any solution and it was the engineer who pointed out that you had responded to my 16th post.  I want to express my sincere thanks for your detailed step-by-step response / instructions with how to handle our dilemma with creating pools within the iapp so that they are created with autopopulate enabled.  Although the instructions contained a small amount of steps; I'm certain you spent some time developing and testing the solution which I can't express enough how your support is appreciated.  I am very happy to report that I finally was able to test everything which worked flawlessly and your instructions were very easy to understand and implement.
Please do let me know if there is anyone I can contact to express our appreciation for your knowledge, professional support and assistance.
The last remaining item I have on my list to do within this iapp will be to enable HSTS when the http profile is created. I suspect if it is still not natively supported in the http iapp, your assistance here will be a guide of the similar steps I will need to look into.
Warmest Regards, Robert Booth Sr. Network Engineer Ventech Solutions | HIDS
