iApp exchange 2013 Login issue
I am using the latest iApp deployment guide for exchange 2013 on LTM v11.5. I see that the iApp doesnt add any persistent profiles for owa. After i just use the iApp to deploy and try to login to my OWA, i am again thrown the same OWA login screen again. This behaviour is without having any persistence. But when i just added a source address persistence to the virtual server, i see that i can successfully login. So my query is the persistence definitely needed for OWA to work? If thats the case why is it that the iApp doesnt include the persistence as part of its template? Also, if the persistence is surely needed, please do let me know the F5 recommended persistence that should be used for different services in exchange 2013. It would be really helpful if someone could help me clarify my query. Thanks in advance.
Regards Sundar
Hi Sundar, persistence is not required for OWA 2013.
I ran into this issue before, and IIRC it’s a configuration on the Client Access Server. I can’t remember off the top of my head what the setting was. Are you able to post the output of the Powershell command “Get-OWAVirtualDirectory”?
thanks
Mike
I found the info from the last time I encountered this problem. Are you doing SSL bridging? If so, do the certificates on your CAS contain the host name used to access OWA, and do they both match the cert you’re using to decrypt on BIG-IP?
Hi Mike, First of all thanks for your response. Yes we are doing SSL Bridging. Currently, all the certs we are using are self signed certs and as mentioned by you the certificates arent the same. So to confirm, i need to have the same certificate/private key as the OWA server on my BIG-IP for decrypting? Is my understanding correct?
That’s correct. You can use a self-signed cert, but you need to copy it to and import it on all your CAS, as well as the BIG-IP.
Thanks Mike. Just another clarification, can i know why exactly there is no need for persistence in Exchange 2013? Is it because of the exchange 2013 behaviour? Also how does the certificate really impact the persistence? Thanks Sundar
This explains why better than I can: http://blogs.technet.com/b/exchange/archive/2013/01/25/exchange-2013-client-access-server-role.aspx OWA 2013 with FBA uses the SSL private key to identify the session, rather than the session cookie.
Thanks mike will check out the link. Regards Sundar
Hi Mikeshimkus,
Please assist have an issue on site OWA on exchange 2013 is been load balanced effectively but outlook has ssl certificate errors and its not connecting , please assist i need to know why owa is effectively load balanced but Outlook cant connect.
Regards
See my comment in the other thread.
