I want to evaluate character string of Cookie by a hex digit.
Hello all.
I’m Japanese.I am weak in English.
But I do my best.
This cookie is “EX=…” by random of hex string.
A character is “0” to “f”
I wrote following iRule.
if { [HTTP::header exist “cookie”] }{
switch [findstr [HTTP::cookie “cookie”] “EX” 3 1] {
“0” {
use pool A_pool
“1” {
use pool B_pool
“2” {
use pool C_pool
“f” {
use pool Q_pool
This Rule is a description to check 1 character.
But,I would like to check 2 character.
The case of “00” to “0f”,use pool A_pool.
The case of “10” to “1f”,use pool B_pool.
The case of “20” to “2f”,use pool C_pool.
The case of “f0” to “ff”,use poll Q_pool.
In this case, It is very troublesome that I write each.
Therefore I want to make the value that I acquired a number.
Can you achieve this problem?
Thanx and regards.
What you need there is the ‘scan’ command, http://tmml.sourceforge.net/doc/tcl/scan.html , and I believe you’d want something like this:
  if { [HTTP::header exist "cookie"] }{
    scan [HTTP::cookie "cookie"] "EX%2x" cookieval
    if { $cookieval <= 15 } {
      use pool_1
    } elseif { $cookieval > 15 ....
Hope that helps,
Aaron
Aaron-san
Thank you for your reply.
But,As for this solution, management is difficult.
I want to make string “00” equals hex number “00”.
An ideal condition is as follows.
switch [extra-rule] {
“00”-“0f”{
use pool A_pool
“10”-“1f” {
use pool B_pool
“20”-"2f {
use pool C_pool
“f0”-“ff” {
use pool Q_pool
Is it difficult about this?
Am I selfish?
Thank you.
Thank you.
Is there the person who can solve my trouble elsewhere?
If all 00 - 0f is going to the same pool, why do you need to evaluate the second character?
