The following string is being used -
http://bsccsupplierpayables2.sysco.com/imageserver/getimage?folders=1463,52c,52b,52b,52b,52b&docids=1ba54,788a5,1fb73,1fb74,1fdf2,1fdf7
I have tried two different irules and neither works. Please help. The keyword that changes is getimage and so that is what I am trying
to use. It seems like the irule is not catching it. The 8080 pool references the server using port 8080. The 80 pool references the same server but using port 80. If it works correctly a PDF file will be called and load. When it doesn’t I get an invalid file request so it is easy to test.
First version -
if (tolower(http_uri) contains “getimage”) {
use pool bscc.sysco.com-8080
else {
2nd version -
if (http_uri contains “getimage”) {
else if (http_uri matches_regex “(reportNames)”) {
else if (http_uri matches_regex “(reportParams)”) {
else if (http_uri matches_regex “(getReport)”) {
else if (http_uri matches_regex “(getimage)”) {
else {
