hi whenever i try to access this below page thru WA is does not give me any results however when i access the same thru node it works fine..can some one help me with a i rule to by pass this page..
Why do you think you need an iRule to fix this? What would you want the iRule to do?
Can you provide more information on the failure symptoms? Do you see any response come back? Do you see this issue for any other requests? If you do see any response come back from the VIP, how does it compare with the response that’s sent directly from the node? Do you see any relevant errors in /var/log/?
Have you opened a case with F5 Support on this yet?
Aaron
