I have created a i-rule to redirect the when http host contains siteA, & uri starts with search, sent it to SiteA _3737pool.
if http host contains siteA, & uri has ‘sales’ or FinanceBuyCatergory’ words, it has to send request to pool Finance_443 .
Else send request to default pool SiteA_443.
Kindly check and let me know if i’m doing something wrong in logic. I see the request are not being send to backend pools .
Note: Pool SiteA is attached to VIP where as pool Finance is not attached to VIP and acting a independent pool.
irule:
if { [HTTP::host] eq “SiteA” and ([HTTP::uri] starts_with “/search/”) }{
SSL::disable serverside
pool SiteA_3737
elseif { [HTTP::host] eq “SiteA” } {
switch -glob [HTTP::uri] {
“*sales*” -
“*FinanceBuyCategory*” {
pool Finance_443
else { pool SiteA_443
Snl
2
you can achieve the same easily using LTM Traffic policy
Thank you,
LTM Traffic Policy is not enabled in F5 box.
Can you help on irule?
Hi T Rajneesh,
Can you try this iRule?
if { ([string tolower [HTTP::host]] equals "sitea.com") or ([string tolower [HTTP::host]] equals "www.sitea.com") } {
switch -glob [string tolower [HTTP::uri]] {
"/search/*" {
log local0. "[HTTP::host] [HTTP::uri] iRule redirect SiteA_3737"
pool SiteA_3737
"*sales*" -
"*financebuycategory*" {
log local0. "[HTTP::host] [HTTP::uri] iRule redirect Finance_443"
pool Finance_443
log local0. "[HTTP::host] [HTTP::uri] iRule no redirect"
# if you use default pool, no need 'pool SiteA_443'
# pool SiteA_443
If it doesn’t work, can you check the logs?
HI,
My first rule is working fine. i.e., search one.
i have issue when uri has ‘sales’ or ‘FinanceBuyCatageroy’.
Regards,
Rajneesh
