i rule for traffic redirection
I need your help in writing on irule -
if the request is coming from x.x.x.x and y.y.y.y and z.z.z.z then go to pool A Else go to Virtual server B
Thanks.
You can use the following irule or an ltm policy (http traffic) :
when CLIENT_ACCEPTED {
        if { [class match [IP::client_addr] POOL_A_IPS] } {
            pool pool_a
            virtual virtual_server_b
POOL_A_IPS is a datagroup containing your IP addresses x.x.x.x, y.y.y.y and z.z.z.z
            pool pool_a
You can also change the Event context for http traffic for example :
        pool pool_a
        pool pool_a
Hi Yann,
You have been great help for many of my queries. I would test this one and update if it works.
Hi Yann,
