Hi Guys, is there a way when writing an i-rule to send the http request to a website if the site captured as a variable from HTTP::host ? thanks Jean
Jean: If I understand your question correctly, yes this should be easy to do. Have a look at the following link for information. At the bottom you’ll see several rules that will hopefully give you some useful examples: http://devcentral.f5.com/wiki/default.aspx/iRules/HTTP\_\_host.html
-Matt
