I-rule between VIPs on two different physical F5's
Hi All,
We have an i-rule which forwards request from F5 VIPA to F5 VIPB. VIPA is on F5 device in location A and VIPB is on another F5 device in location B.
VIPA: Bunch of servers under a pool, all listen on 80, the servers are in same location as of F5 VIPB: Bunch of servers under a pool
I-rule was written on VIPA to forward request either to VIPB or to it’s own default pool.
when HTTP_REQUEST { set usessl 0 switch -glob [HTTP::path] { “/xyz/us/" - "/xyz/uk/” { snat xx.xxx.xxx.xxx set usessl 1 pool vipb-443} default { set usessl 0 pool defaultpool-80
} } } when SERVER_CONNECTED { if { $usessl == 0 } { SSL::disable } }
Pool vipb-443 has just one member that’s VIPB with 443 port pool defaultpool-80 has bunch of servers in same location as of VIPA
I have a flow on a page hosted on VIPA which loads data from a page in VIPB and then comes back to pool members of VIPA for some other processing.The issue is when a http request is going thru this I-rule, the first part xyz/us that goes to VIPB is successful and in default path it throws error_inertnet_connection_reset.
The tcpdump shows that VIPA LTM sent a RST command to server(default pool member).
Any help would be greatly apprreciated.
what persistence is applied to the VIP?
I would guess that the SSL disable is happening too late.
I would try the third example is this post DevCentral - An F5 Technical Community
From the post … Note: Disabling SSL on the serverside only applies before serverside connection has been established (SERVER_CONNECTED) or when the clientside of the connection is in a detached state (e.g., oneconnect, LB::detach).
Source Address Persistence
Thank you, will try the 3rd option and post the out come here
No luck. The first call to Intial page load on VIPA itself failed with error internet connection reset error
Here is the solution, we added snat in default path as well. Snat to local ip of load balancer, that resolved the issue.
