Iif you click edit and then save on your post, the HTML encoded ampersands will be reset to normal ampersands.
Also, you can remove the space between - and glob, and set the capital P in the first and third URIs to p to make the matches work.
Aaron
Modified - Thanks for catching the upper case Ps. I had hoped wrapping the code in the code tags would’ve kept the board from screwing with the HTML but guess not.
