GTM/LTM device
You should be able to run two modules on v11 if you have a 1600 or newer. Always check version specific documentation first though.
Here’s more information:
/Patrik
It’s very hard to answer this question without knowing the requirements of your customer (throughput etc), the network design and links between the data centers.
I would recommend you to contact your F5 partner for technical advice regarding the implementation.
/Patrik
