Hello F5 Experts.
I am New to F5 and iRules, I am helping my team to troubleshoot an iRule Issue, Basically the Irule is already in place which is to allow only the IPs listed in the iRule to have access to the Backend Servers. The iRules looks likes this when HTTP_REQUEST {
if { ([string tolower [HTTP::uri]] contains "/devicexx/enxx") ||
([string tolower [HTTP::uri]] contains "/devicexx/enxx/airxx.aws") } {
switch [IP::client_addr] {
"62.x.x.x" {
"62.x.x.x" {
"202.x.x.x" {
"204.x.x.x" {
default {
log local0. "Matched default policy: Access Denied"
reject
But the issue here is that the iRule is not blocking the IPs which are not listed here. Any help is much appreciated.
PS: I am replacing some portion of the URI and Public IPs for security reasons
This may be a good application for a data-group. It may make management of the allowed IP addresses easier. If you create an internal data-group called ‘allowed_ips’, the iRule below will reject connections that are not sourced from an IP in the data-group.
Also for your string match, both entries contain ‘/devicexx/enxx’, so the OR is superfluous. That is, unless the information you redacted is different between the entries?
if { ! [class match [IP::client_addr] eq allowed_ips] } {
reject
You can use the following irule to disallow access to specific urls to users :
if { [string tolower [HTTP::path]] starts_with "/devicemanagement/enroll" or [string tolower [HTTP::path]] starts_with "/deviceservices/enrollment/airwatchenroll.aws" and ![class match [IP::client_addr] equals irdg-mdm-test] } {
log local0. "[IP::client_addr] - Matched default policy: Access Denied"
reject
return
This irule will allow IP addresses defined in the datagroup named irdg-mdm-test to access specified urls. Other IPs will be rejected.
Maybe, you can also change the
reject
command to something more user friendly like
HTTP::respond 403 content "Request Not Allowed"
Note : Pay attention that you don’t have other irules, LTM policies or whatever else that bypass this irule processing.
reject
return
reject
You may also expect something more scalable :
if { [class match [HTTP::path] contains url-mdm-test] and ![class match [IP::client_addr] equals irdg-mdm-test] } {
reject
return
reject
return
Yann,
I have changed the iRule to above but connections are still being allowed when I try to access from an machine not from this list.
Yann,
Hi updated the irule above. Can you check that you get the logs from the irule in the /var/log/ltm logfile ?
Do you have some proxy or reverse proxy between F5 and the client ?
