hi guys 1. client ssl off_load VIP is on port 443 and pool members also in service port 443 . 2. pool members can not change port (also 443 ) They want to do ssl offload on the VIP will it work???
help me please
Providing you have an HTTP profile and a client-ssl profile it will work as F5 is a full TCP proxy. Having both the virtual server and pool members on the same port will not affect the connectivity and the ability off load SSL.
Your server backend listen in https too?
in this case it’s not ssl ofload but interception and you need ssl client and ssl server profile.
regards
hi The server only use port 443. server side do not encryption.
