hi guys: I have a irules need:1.i have three pools;2.When the current total number of connections in pool1 is greater than 2000, the new connection is then load balance by pool2 and pool3.
The three pool load balancing methods are based on the data content. I can write the rules of this requirement.
Hi Lizunjjg,
I think if you refer this codeshare, you can achieve your requirement.
Let me know how it goes, so it would be something like below,
when RULE_INIT {
set static::max_active_clients 2000
test cookie presence
if {[HTTP::cookie exists "ClientID"]} {
set need_cookie 0
set client_id [HTTP::cookie "ClientID"]
if cookie not present & connection limit not reached, set up client_id
if {not ([table keys -subtable httplimit] > $static::max_active_clients)} {
set need_cookie 1
set client_id [format "%08d" [expr { int(100000000 * rand()) }]]
Only count this request if it's the first on the TCP connection
if {[HTTP::request_num] == 1}{
table set -subtable httplimit [IP::client_addr]:[TCP::client_port] "blocked"
set timer [after 60000 -periodic { table lookup -subtable httplimit [IP::client_addr]:[TCP::client_port] }
Selecting pool2 as the 1st pool reached connection limit
pool pool2
when HTTP_RESPONSE {
insert cookie if needed
if {$need_cookie == 1} {
HTTP::cookie insert name "ClientID" value $client_id path "/"
when CLIENT_CLOSED {
decrement current connection counter for this client_id
after cancel $timer
table delete -subtable httplimit [IP::client_addr]:[TCP::client_port]
