I cannot not make trunk interface.
Hi All,
I have a BIG-IP 2000s and a 4000s. I would like to make trunk port with port 2.1 and 2.2. However as the image, I cannot do it with the error messages, “Interface 2.2 media is incompatible with other trunk members”
I tried the following actions;
  • After installing the new OS on the other volume, I try to make trunk with port 2.1 and 2.2
  • After I delete all of trunk port and I try to create trunk again.
  • After type “tmsh load sys config file default” command and log on and then try to create trunk port with port 2.1 and 2.2.
I cannot be resolved with above the actions. Both BIG-IP 2000s and 4000s have same issue. However, except port 2.1 and 2.2, I can create the trunk port with the other ports.
Is there anyone who has been experiencing this problem?
Help
Thank you
The interfaces are disabled - try enabling them and getting them to an Up state. Check that they have the same SFP in them as well.
this is mine.
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys hardware | grep -A 4 Platform
Platform
  Name           BIG-IP 4200
  BIOS Revision  OBJ-0433-xx Build: 2.00.163.0 08/23/2013
  Base MAC       00:23:e9:5a:ef:00
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) show sys version
Sys::Version
Main Package
  Product  BIG-IP
  Version  11.5.1
  Build    0.0.110
  Edition  Final
  Date     Wed Mar 12 15:44:53 PDT 2014
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) show net interface 2*
Net::Interface
Name    Status  Bits  Bits  Pkts  Pkts  Drops  Errs  Media
                  In   Out    In   Out
2.1   disabled     0     0     0     0      0     0   none
2.2   disabled     0     0     0     0      0     0   none
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) create net trunk test interfaces add { 2.1 2.2 } lacp enabled
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) list net trunk test all-properties
net trunk test {
    app-service none
    bandwidth 0
    cfg-mbr-count 2
    description none
    distribution-hash src-dst-ipport
    id 0
    interfaces {
        2.1
        2.2
    lacp enabled
    lacp-mode active
    lacp-timeout long
    link-select-policy auto
    mac-address 00:23:e9:5a:ef:38
    stp enabled
    type normal
    working-mbr-count 0
root@(B4200-R77-S9)(cfg-sync Standalone)(Active)(/Common)(tmos) show net trunk test
Net::Trunk
Name  Status  Bandw  Bits  Bits  Errs  Errs  Drops  Drops  Colli
               Mbps    In   Out    In   Out     In    Out  sions
test    down      0     0     0     0     0      0      0      0
  | Net::LACP Status (trunk: test)
  |                      SysID  Key  Priority
  | Actor    00:23:e9:5a:ef:00    1     61184
  | Partner               none    0         0
Thanks for all.
This is a known issues. I resolved that after I performed as follows;
Thank you.
