I am trying to connect F5 using terraform and getting below error
It might be a caching issue. Try deleting the terraform directory and lock file and then try terraform init command again. Let me know how it goes.
Cheers,
Rodrigo
I found it. The script is fine but need to add the resource module what we need to create using terraform. After added below steps in the existing script and it started working, So learning here using terraform to connect F5 will not give any message like " the device is connected" More over i didn’t define the SSH or https port to the script that should be also considered one.
resource “bigip_ltm_node” “node” { name = “/Common/terraform_node1” address = “192.168.30.1” connection_limit = “0” dynamic_ratio = “1” monitor = “/Common/icmp” description = “Test-Node” rate_limit = “disabled” fqdn { address_family = “ipv4” interval = “3000” }}
This is a whole script
variable hostname {}variable username {}variable password {}terraform { required_providers { bigip = { source = “f5networks/bigip” version = “1.13.0” } } }provider “bigip” { address = var.hostname username = var.username password = var.password}resource “bigip_ltm_node” “node” { name = “/Common/terraform_node1” address = “192.168.30.1” connection_limit = “0” dynamic_ratio = “1” monitor = “/Common/icmp” description = “Test-Node” rate_limit = “disabled” fqdn { address_family = “ipv4” interval = “3000” }} Verified in F5 and it is created a node using terraform.
Rodrigo_Albuque - Thanks to you man for quick turn around.
