Hyper-V and Tagged VLANs
Hello,
I have a very weird problem which I can’t seem to resolve by myself.
I have a BIG-IP LTM up and running on HYPER-V with 4 virtual legacy interfaces.
The first legacy NIC is automatically assigned to MGMT.
The 2nd legacy NIC (1.1 on the BIG-IP) is untagged and I can ping the SELF-IP just fine.
The 3rd legacy NIC (1.2 on the BIG-IP) is also untagged and I can ping the SELF-IP just fine.
The 4th legacy NIC (1.3 on the BIG-IP) is tagged with two VLANs, the first VLAN tag is 1000 and the 2nd VLAN tag is 1100.
I have created a Self-IP per VLAN and for some very odd reason I can’t ping the Self-IPs from there corresponding VLANs.
I have configured the NICs on the VMs settings to use tag 1000 and 1100 respectively and still ping fails.
What am I doing wrong?
Please help!
TIA,
Jr
I got this resolved.
Apparently I was using “Private” VNICs which do not support VLAN tagging or traffic, once changed to Internal VNIC things started to work just fine.
Thx,
Jr =]
there’s a couple of things worth pointing out about Hyper-V deployments of BIG-IP VE:
(These can be found in the manual too, but here’s a concise little guide):
1) You can have up to four Legacy Network Adapters assigned to the BIG-IP VE Hyper-V Virtual Machine container. You’ll probably want three at a minimum for an Internal and External network, but BIG-IP is quite flexible and will fit 1 to 3 data plane interfaces handily.
2) To use a VLAN tag:
2.1) VLAN tags can be configured on the Legacy Network Adapter (Hyper-V configuration)
- open the nic on the vm
- [x] Enable virtual LAN identification
- Put in a VLAN ID value to use for tags
2.2) Configure VLANs to use untagged interfaces (BIG-IP configuration)
2.3) Configure the receiving device to accept and send the correct VLAN tags (switch, router, BIG-IP hardware, Hyper-V server, etc.)
So I’m back at the beginning…
According to what is written above, I can’t create multiple tagged VLANs on the same interface.
I need to have at least two tagged vlans using one internal vSwitch, Is there a way to work around this?
TIA,
Jr
It’s a Hyper-V limitation that I’ve not found a way to work around. Passing tags from the guest into a virtual switch or onto the wire doesn’t seem to function.
If you really need to pass tags from BIG-IP Virtual Edition, Xen and VMware support passing guest tags into virtual switch infrastructures.
No exactly… You can indeed use hyperV to do exactly as you wish…
Powershell as admin on host…
set-vmnetworkadaptervlan -trunk -allowedvlanidlist “222,250,263” -vmname f5ve001 -vmnetworkadaptername f5ve001 -nativevlanid 1
It works.
mkinder
