Hello everyone!
I am having an issue I am hoping to get some help with.
Setup:
1 HTTPS Virtual Server with IP a.a.a.a port 443 doing SSL offloading to b.b.b.b on port 80. Site A Working! 1 HTTPS Virtual Server with IP a.a.a.a port 8000 doing SSL offloading to b.b.b.b on port 8000. Site B not working. 1 HTTPS Virtual Server with IP a.a.a.a port 8011 doing SSL offloading to b.b.b.b on port 8011. Site C not working.
I have deployed all 3 with the F5 HTTP iApp. I am seeing no traffic to my pools for site B and C.
I am getting this from both sites B and C in a tcp dump:
Transmission Control Protocol, Src Port: 65265, Dst Port: 8011, Seq: 0, Len: 0
Source Port: 65265
Destination Port: 8011
[Stream index: 0]
[TCP Segment Len: 0]
Sequence number: 0 (relative sequence number)
Acknowledgment number: 0
Header Length: 32 bytes
Flags: 0x002 (SYN)
000. .... .... = Reserved: Not set
...0 .... .... = Nonce: Not set
.... 0... .... = Congestion Window Reduced (CWR): Not set
.... .0.. .... = ECN-Echo: Not set
.... ..0. .... = Urgent: Not set
.... ...0 .... = Acknowledgment: Not set
.... .... 0... = Push: Not set
.... .... .0.. = Reset: Not set
.... .... ..1. = Syn: Set
[Expert Info (Chat/Sequence): Connection establish request (SYN): server port 8011]
[Connection establish request (SYN): server port 8011]
[Severity level: Chat]
[Group: Sequence]
.... .... ...0 = Fin: Not set
[TCP Flags: ··········S·]
Window size value: 8192
[Calculated window size: 8192]
Checksum: 0x66c3 [unverified]
[Checksum Status: Unverified]
Urgent pointer: 0
Options: (12 bytes), Maximum segment size, No-Operation (NOP), Window scale, No-Operation (NOP), No-Operation (NOP), SACK permitted
[SEQ/ACK analysis]
[iRTT: 0.000018000 seconds]
[TCP Analysis Flags]
[Expert Info (Note/Sequence): This frame is a (suspected) spurious retransmission]
[This frame is a (suspected) spurious retransmission]
[Severity level: Note]
[Group: Sequence]
[Expert Info (Note/Sequence): This frame is a (suspected) retransmission]
[This frame is a (suspected) retransmission]
[Group: Sequence]
Anyone have any ideas what might be the issue here? I can post more info if need be.
