When accessing URL https://www.abc.com/404.php but HTTPS is not enabled so please help me to redirect to http for URL
Thanks in advance Yugraj Rai
If this is a response coming from the back end server you are load balancing you could apply a stream profile and use an irule to replace the URL:
when HTTP_RESPONSE {
STREAM::expression {@https://www.abc.com/404.php@http://www.abc.com/404.php@}
Enable the stream filter for this response only
STREAM::enable
Disable the stream filter by default
STREAM::disable
STREAM::enable
STREAM::disable
Sorry missed some of the irule when HTTP_RESPONSE { Check if response type is text if {[HTTP::header value Content-Type] contains “text/”}{ STREAM::expression {@https://www.abc.com/404.php@http://www.abc.com/404.php@} Enable the stream filter for this response only STREAM::enable } else { Disable the stream filter by default STREAM::disable } }
If you are running v11.4.0 or later, it may be better to do this without iRules in local traffic policy. If not yet running v11.4.0 or higher, use this iRule and apply to your port 443 virtual server (assuming you have a separate virtual server for 80 and 443. If not, create separate ones):
HTTP::redirect http://[getfield [HTTP::host] ":" 1][HTTP::uri]
HI All
Currently we are using “BIG-IP 10.2.1 Build 511.0 Hotfix HF3” version. when i create Irule and associated with my virtual server it throw an error like "010703943:3: STREAM::expression in rule(abc) requires an associated STREAM profile on the virtual serever (Virtual server Name)
Thanks Yugraj Rai
just assign default stream profile to the virtual server.
agreed has to be applied before the irule, on the main properties tab of the virtual server (think you have to use the drop down to view the advanced settings)
Hi All Finally issue has been resolved as i created one virtual server listen on 443 port and use Irule provided by Cory. Thanks a lot for the support.
Thanks Yugraj Rai
Glad to hear.
