https traffic through LTM with fallback host
I am trying to create a https virtual server to pass ssl traffic across to our servers.
That is, I am trying to pass the traffic directly to the server without having LTMs encrypt/decrypt request.
And I am trying to use a Fallback Host with HTTP profile.
That is, when the pool member of https virtual server is down , then the connection should redirect to http://sorry.domain.com/.
I understand in this scenario, an HTTP profile cannot be used.
Isn’t there any method of realizing some requirements?
Hi Toto,
You can use an iRule for this:
You’ll need to import the server SSL cert/key so that TMM can decrypt the HTTPS and send a response when the pool is down. If the pool is up, no decryption is done on TMM.
Aaron
