HTTPS-to-HTTPS redirect
Hello,
I am trying to redirect an https URL to another https URL and am not able to. Can someone let me know if this is possible? My rule scenarios are below.
virtual 12.x.x.x:443 unit 1 {
use rule RDC-Redirect-test
rule RDC-Redirect-test {
if (http_host contains “app.domain1.com”) {
redirect to “https://myapps.domain2.com/%u”
else {
discard
Davean,
this cannot work unless you first decrypt the SSL. The rule parser cannot match the HTTP Host header (which is what the http_host directive is looking for) in the encrypted content. The connection has to be handled by SSL proxy using your virtual as a back-end. The configuration may look like this:
   if (http_host contains "app.domain1.com") {
      redirect to "https://myapps.domain2.com/%u"
   else {
       discard
virtual 127.0.0.1:8888 unit 1 {
proxy 12.x.x.x:443 unit 1 {
   target virtual 127.0.0.1:8888
   clientssl enable
   clientssl key
   clientssl cert
Caveats: you either need to move the certificate from your server to the BIG-IP or get a new one.
I figured the encryption had something to do with it. unfortunately another certificate is not an option right now. I appreciate the info. This was a great of help!! Thanks!
Actually, I took what you said and created a self signed certificate. since it redirected the request I didn’t get prompt that this certificate was not valid, which is what I didn’t want my users to see.
Thanks for the direction/resolution!
