HTTPS to HTTP
Im attempting to forward https requests to http.
I’m running BIG-IP v12.1.1 (Build 0.0.184) Virtual edition.
Currently if I access the server directly everything responds as expected. How does one setup the virtual server ?
At the moment the Virtual server is setup to listen on port 443 and the node is set to port 80. To get any response from the server i have had to add clientssl-insecure-compatible.
1.1.1.1/sap/bpc/web/ is the url.
Are you wanting to SSL Offload on the F5 ?
You’ll need a client SSL Profile likely with CERT + Key combo.
I think in this instance id like the f5 to handle the ssl session.
If I understand you question correctly you want to use SSL Offloading. So speak encrypted to the client but plaintext to the server. In this case you need to assign a client-ssl profile, but no server-ssl profile. Afaik there is no client-ssl-incompatible per default. The client-ssl profile is used for the VS, where the client connection is terminated. So the client-ssl profile is the one, which uses the cert-key pair.
If this is not what you have expected, please provide more information. What is the reponse of the BIG-IP, when you access the VS?
Greets, svs
Terminate SSL on the F5 and send unencrypted traffic to the pool members listening on port 80.
