Hi guys, anyone knows how to irule https://www.xxx.com to http://www.xxx.com?
would it be something like:
if (https_uri contains “/xxx.html” ) {
use pool http_pool
Thanks a lot
Cris
use pool http_pool
Thanks a lot
Cris
Are you wanting to have the BIG-IP accept HTTPS traffic, decrypt it and send HTTP to the pool? If so, you don’t need a rule. You can configure an SSL proxy, a loopback virtual server and a pool.
Check the BIG-IP Reference Manual for your version for details. Here is the 4.5.10 chapter:
SSL Accelerator Proxies
If this isn’t what you’re trying to do, please elaborate.
Aaron
