3) anyone who goes https://sitename WITH THE EXCEPTION of the /contact page MUST goto HTTP VS
I’ve been looking at the HTTP Class profiles as you can do redirects with them, the problem I have is with a simple redirect if you goto https://sitename/contact it goes into a loop and IE just errors, Safari actually tells you it’s looping. ALL other pages are fine.
So I see that you can define URI Paths within the class to match for so I’m trying to add a rule in the HTTPS redirect that says send ALL HTTPS traffic to the HTTP site that DOES NOT match /contact.
I just don’t seem to be able to get the regex right for this - anyone help?
Note: also posted a question about this in the iRules section, but I reckon this will work just as well.
What was frustrating is the LTM guide states that the LTM’s use “ARE / Advanced Regular Expressions” and the examples were very basic. I just couldn’t find any decent documentation on “ARE” - saying that I’m no expert on regex at all, so maybe there isn’t a great deal of difference?
I’ll study your very simple response and try to understand exactly what it’s doing.
