Hello All,
I have two vips setup, one for http and one for https. I’ve put in place an http to https redirect on the http vip and it is working as expected.
if { [HTTP::host] equals "test.domain.com" } {
HTTP::redirect https://test.domain.com/app/login.do
My issue is the https side of things, if someone tries to go to “https://test.domain.com” directly and I try to use the same irule as above on the https vip, I keep getting stuck in a redirect loop. I don’t see an HTTP::rewrite command, so how might I go about trying to do a rewrite instead?
TIA,
DarkSide
When you look at [HTTP::host] it’s going to be true if it looks like this
or
or
https://test.domain.com/whatever/
This is why it’s going to keep redirecting and looping through the same irule
What you need to do is determine if there is a uri, meaning “/app/login.do”
So you rewrite the logic
if { ([HTTP::host] equals "test.domain.com") and [HTTP::uri] equals "/" } {
This should then only trigger the redirect when the request hits the vip as http(s)://test.domain.com/
hope this helps
CB
I appreciate the assistance CB, it certainly helped. I had begun thinking that I might need 2 iRules to accomplish my goal and was uncertain how to handle the https side. Using only one make things much easier.
Thanks,
-DarkSide
Ok, as I mentioned this is working, but now they’ve come back and asked me to do something that should be handled at the app layer. They have a web console that is used to change parameters of the app server. Rather than putting a password on it like they should, they want me to drop any requests attempting to access it. I tried using the ‘else’ and ‘elseif’ statements, but they seemed to drop everything. Where have I fallen off the tracks on this???
} elseif { ([HTTP::uri] contains "appconsole" or "qaconsole") } {
reject }
I also tried this with no success???
reject }
TIA
-DarkSide
It looks like because it never get to the elseif line,
it does the redirect on the first couple lines.
Tweak your uri equals line or change the order or logic.
