Not huge into writing rules, but I had hoped I would be able to hack my way through a simple task. Obviously that notion has fallen on its butt.
I need to redirect requests containing a specific string within the URI to only one server; everything else can use any host in the pool. I think I have the syntax correct, though I can’t seem to get the hang of when to use a Server Profile (if at all?) and which one will get things moving.
if { [string tolower [HTTP::uri]] starts_with “/admin” } {
node 10.151.64.141
pool conhugeco_web_pool
I’ve set the Server Profile to HTTP (the VS is listening only on TCP/443). Nothing good happens. Actually, nothing happens. Even if I disable the iRule and leave everything else alone, there’s no F5 love.
I realize that this may not have anything to do with the actual iRule, but I’m unsure how the Server Profile selection (and maybe other settings) effect the use of an iRule.
I’ve added the “log” line, but don’t get anything posted to the log. This leads me back to the notion that I’ve hosed something with the VS setup and thus I’m not even getting to execute the iRule.
I realize this is probably a bit out of scope for the regular discussions here, but appreciate any assistance. (And yes, I do have a case opened with TAC.)
