HTTPS Redirect for a specific URL, URI
I have an iRule that I have written that I think will do what I need it to do but would like someone to confirm this, or tell me what’s wrong. (Joe is just an example)
if {([HTTP::host] equals “www.joe.com” and
([HTTP::uri] equals “/net/myjoe”)}
{ HTTP::uri “https://www.joe.com/net/myjoe”
When a client request “http://www.joe.com/net/myjoe” I need them to be redirected to “https://www.joe.com/net/myjoe”.
But if they request any other uri at www.joe.com using http I need that traffic to be passed to the pool.
Will the above iRule work?
This one will do exactly what you are asking:
if { [HTTP::host] equals "www.joe.com" and [HTTP::uri] starts_with "/net/myjoe" } {
HTTP::redirect "https://www.joe.com/net/myjoe"
I find this way to be a little more elegant and flexible.
HTTP::redirect "https://[HTTP::host][HTTP::uri]"
In the first example it will redirect you directly to “https://www.joe.com/net/myjoe”, but the second example is a little more robust. Say you accessed the site with “http://www.joe.com/net/myjoe/content/index.html”.
The first iRule would redirect you to “https://www.joe.com/net/myjoe” striping the “/content/index.html” off of the URL (this could be bad or confusing to the users).
The second iRule would do the following.
Redirect from HTTP to HTTPS
Detect the [HTTP::host] - “www.joe.com”
Detect the [HTTP::uri] - “/net/myjoe/content/index.html”
Put it all together and redirect the user: “https://www.joe.com/net/myjoe/content/index.html”
Thanks Michael,
Both of those will work great. I appreciate you taking the time to reply.
Thanks again,
Randy Mays
am using the following iRule, it works for https but the else line doesn’t take the page back to http. Can anyone assist here? Am I using correct method? I want page to redirect back to http when user move away from /Contact-Us page.
when HTTP_REQUEST { if { [HTTP::host] equals “oaccac-pp.com” and [HTTP::uri] starts_with “/Contact-Us”} {HTTP::redirect “https://[HTTP::host][HTTP::uri]”} else {HTTP::redirect “http//[HTTP::host][HTTP::uri]”} }
Could this simply be a typo.
should this be:
else {HTTP::redirect “http://[HTTP::host][HTTP::uri]”} }
Rgds
N
Are you applying this iRule on an HTTPS VIP?
It’s may be better to simplify it for each.
HTTP VIP:
    if { [string tolower [HTTP::uri]] starts_with "/contact-us" } {
HTTPS VIP:
    if { not ( [string tolower [HTTP::uri]] starts_with "/contact-us" ) } {
        HTTP::redirect "http://[HTTP::host][HTTP::uri]"
Also, I wonder if the request away from Contact Us is in the same connection then you’d need oneconnect on the VIP. Hope I’m right on this…sure I’ll be corrected if not.
Remember that HTTP::redirect will create an HTTP 302 response (Moved Temporarily). If you ever need a permanent redirect for SEO reasons, use HTTP::respond 301 … instead.
Thank you Kevin, it worked. Now I have one more page /feedback and I tried this code but doesn’t work: HTTP VIP: when HTTP_REQUEST { if { [string tolower [HTTP::uri]] starts_with “/contact-us” } {HTTP::redirect “https://[HTTP::host][HTTP::uri]” } elseif { [string tolower [HTTP::uri]] starts_with “/feedback” } { HTTP::redirect “https://[HTTP::host][HTTP::uri]” } }
HTTPS VIP: when HTTP_REQUEST { if { not ( [string tolower [HTTP::uri]] starts_with “/contact-us” ) } {HTTP::redirect “http://[HTTP::host][HTTP::uri]” } elseif { [string tolower [HTTP::uri]] starts_with “/feedback” } { HTTP::redirect “http://[HTTP::host][HTTP::uri]” } } pl. assist.
Try these:
HTTP:
    if { ( [string tolower [HTTP::uri]] starts_with "/contact-us" ) or ( [string tolower [HTTP::uri]] starts_with "/feedback" ) } {
HTTPS:
    if { not ( [string tolower [HTTP::uri]] starts_with "/contact-us" ) or not ( [string tolower [HTTP::uri]] starts_with "/feedback" ) } {
Hi, Thanks so much for your response. I applied http and https rules you provided on each VS. when I click on /contact-us or /feedback, they are broken now. I tried accessing them directly by using URLs as well over http and https but same result - 404 just for those 2 pages. Anything else I can try?
Kvitol, it may be helpful if you posted your configurations. I think something is missing.
This setting worked well for both pages. Thank you guys for assisting.
HTTP VIP: when HTTP_REQUEST { if { ( [string tolower [HTTP::uri]] starts_with “/contact-us” ) or ( [string tolower [HTTP::uri]] starts_with “/feedback” ) } { HTTP::redirect “https://[HTTP::host][HTTP::uri]” } }
HTTPS VIP: when HTTP_REQUEST { if { not ( [string tolower [HTTP::uri]] starts_with “/contact-us” ) and not ( [string tolower [HTTP::uri]] starts_with “/feedback” ) } { HTTP::redirect “http://[HTTP::host][HTTP::uri]” } }
