In our current environment we use SSL offloading for our Exchange 2010 Outlook Web Access through our F5. We need to stop this just for the MRSProxy service and not any other traffic to the server. I created the iRule below and applied it to the virtual server. However we are still seeing the requests for this URL come through on port 80 instead of 443 in the IIS logs on the OWA server. Can anyone help and tell me where I went wrong? Thanks.
if { [HTTP::uri] starts_with “/EWS/mrsproxy.svc”}{
SSL::disable clientside
We are seeing GET /EWS/mrsproxy.svc – 80 in the IIS log and we should get GET /EWS/mrsproxy.svc - 443
No. They are configured for 80 and 443. I can go directly to any of the pool members by their individual IP addresses and hit the URL on 443 without issue.
Scott, I am talking about the load balancer pool configuration, are the members set like this: x.x.x.x:80 or x.x.x.x:*? If the LB sends traffic to port 80, the server will not be listening for SSL.
Aaron, I think he has offloading already and wants to disable that for this particular traffic.
I though that this would be clientside per the document here https://devcentral.f5.com/wiki/iRul…k_URL.ashx. I don’t even have a server side ssl profile defined on this virtual server.
The pool for port 80 is the same as the pool for 443. It should be going to the same pool members. Or does this require a different set of pool memebers entirely?
Brian, yes my pool members were only on port 80. Can I just add the same pool members again on port 443 or should I remove them and the add them back with a * for the port?
Brian, You can’t disable client SSL based on the requested HTTP URI as the SSL would have to have already been used to decrypt the request to parse the URI.
Scott, what’s the actual issue you’re trying to address for this specific URI?
We are engaging with Microsoft to migrate our Student email to Live@EDU which needs to connect to the MRSProxy service at the URL /EWS/mrsproxy.svc. In talking with their support engineer, the process doesn’t support SSL offloading so I just need to disable the offloading only for these requests. The service only accepts encrypted traffic on 443.
Thanks for clarifying. I think you should be able to add a server SSL profile to the virtual server and then disable it for all but the specific URI:
when CLIENT_ACCEPTED {
Save the name of the VS pool before this iRule could change the current pool
set default_pool [LB::server pool]
If the request is for a proxy.svc URI select a separate pool
Leave serverssl enabled
if { [HTTP::path] eq "/EWS/mrsproxy.svc"}{
pool webmail_443_pool
For all other URIs disable serverssl and use the VS default pool
SSL::disable serverside
pool $default_pool
Hi Scott, we need to do exactly the same on our F5, but have never worked with iRules before… can you tell me what I need to do to make this happen? Thanks in advance!
