I’m currently in the process of upgrading my Tomcat servers to Tomcat 7 using the APR connector with SSLv3 disabled. Here is my connector:
Everything seems to be working properly… e.g. going to a page via HTTPS serves up that page correctly. However, we’re using an F5 load balancer and as soon as I disabled SSLv3, the configured health monitor started failing for that node/port. After some troubleshooting on the F5 side, I decided to try to diagnose with OpenSSL:
I’m wondering if that’s what’s causing the health monitor to fail. Either way though, I’m curious why I need to specifically force -tls1 for this to work. I would assume it should auto-negotiate the correct protocol?
This is the cipher list for the corresponding SSL client profile:
ssldump -Aed -nni 0.0 host x.x.x.x and host y.y.y.y and port zzz
x.x.x.x is non-floating self ip on pool member vlan
y.y.y.y is pool member ip
zzz is pool member port
i do see tls 1.0 (version 3.1) on 10.2.4 unit here.
configuration
[root@ve10a:Active] config tmsh list ltm pool foo
ltm pool foo {
members {
200.200.200.101:https {
session monitor-enabled
monitor myhttps
[root@ve10a:Active] config tmsh list ltm monitor https myhttps
ltm monitor https myhttps {
cipherlist "DEFAULT"
compatibility "enabled"
defaults-from https
interval 5
send "GET /\r\n"
time-until-up 0
timeout 16
ssldump
[root@ve10a:Active] config ssldump -Aed -nni 0.0 host 200.200.200.101 and port 443
New TCP connection 1: 200.200.200.15(47647) <-> 200.200.200.101(443)
1 1 1418277963.7661 (0.0021) C>SV3.1(98) Handshake
ClientHello
Version 3.1
random[32]=
54 89 34 4b 5f 01 b2 f2 78 40 27 65 6e 21 b7 0b
dc 7a 94 61 92 36 dc 23 ad 81 b4 a4 d0 31 da 1a
resume [32]=
c7 09 9b ad 17 b5 09 e7 78 c1 91 91 87 64 a9 42
69 1b 87 60 ed 45 fd d2 39 97 41 6b 19 4d e8 c5
cipher suites
TLS_DHE_RSA_WITH_AES_256_CBC_SHA
TLS_DHE_DSS_WITH_AES_256_CBC_SHA
TLS_RSA_WITH_AES_256_CBC_SHA
TLS_DHE_RSA_WITH_3DES_EDE_CBC_SHA
TLS_DHE_DSS_WITH_3DES_EDE_CBC_SHA
TLS_RSA_WITH_3DES_EDE_CBC_SHA
TLS_DHE_RSA_WITH_AES_128_CBC_SHA
TLS_DHE_DSS_WITH_AES_128_CBC_SHA
TLS_RSA_WITH_AES_128_CBC_SHA
TLS_RSA_WITH_RC4_128_SHA
Unknown value 0xff
compression methods
unknown value
NULL
Once I made this change the monitor kicked in immediately. Specifically, it seems that the issue is with the SSLv2Hello handshake. When I removed it from my config the monitor stopped working. This tells me the monitor is relying on the SSLvHello handshake. Is there any way to force the monitor to use TLSv1 instead? I tried specifying that in the cipher list but it didn’t seem to help.
Monitors are run out of OpenSSL. If you want to run 10.2.4, you need HF10 to disable SSLv3 for monitors. You can verify my comment with the command openssl ciphers -v ‘ALL:!SSLv2’ If all you see is SSLv3, then you know you cannot turn off SSLv3 expecting TLS monitors.
