I have an issue where we are re-directing http > https and adding some extra lines to a URI on the port re-direct.
When we target the Virtual server directly on HTTPS the re-direct is missed, and we just see the Admin page.. so ther serverside is not capible of the re-direct without the extended URI.
I need a solution in the HTTPS virtual server to match the Hostnames and ensure that they have the extra URI string to hit the web server directly.
the issue is.. if you just type https://mysite.com you are not redircted and you dont hit the /something site that produces the server re-direct that makes it work.. you just hi the default server admin page.. which is wrong.
what i need is to match if nothing is typed into the browser after mysite.com and force a redirect with the /something added on for that condition.
are you using irule to redirect from http://mysite.com to https://mysite.com/something? if yes, have you assigned the irule (which is being used by http virtual server) to https virtual server?
