I have one http VS and one https VS (client side profile attached) and I am using the same pool for both.
In client side profile I configured client certificate ignored. Now the problem is that when client dials for the first time it takes upto 4 seconds and 2nd, 3rd requests takes 40ms to 70 ms. While http from the same client takes takes 14ms.
Now I am in trouble that why https is taking so long in first request. There is no problem in the network as I am a network guy.
No I am not using self-signed certificate, its been provided by the Company. But even when I removed the certificate and applied default certificate its still the same delay. As client is not using any certificate and I have configure the client side profile in which I have configured to ask client certificate (ignored). So certificate is not in action.
I might also recommend adding the ‘-vv’ option to curl in Kunjan’s suggestion to increase verbosity. It may help indicate if a particular portion of the negotiation/connection is hanging. -Ed
