A request is made to the server as https but when selecting a page link, the response back to the client is shown as http and the connection fails. The problem can be resovled by adding the “s” back in the URL and now the link functions. What can be done to prevent this?
Do you mean to say that the server sends back a 301 or 302 response with http://… specified? You can either get the server to correct its responses, create a second vip for port 80 that uses the https_redirect irule, or rewrite the responses with an iRule(not recommended)
I think we are close but just to make sure, you are correct the client does see an http:// link but why is it not https if the F5 is doing SSL off-loading? If I understand correctly the response going back to the client should be SSL.
