Hi All,
I am trying to validate the VIP, which is failing in the browser stating that “connection reset”,
The server that is mapped to the pool is green via the health check, i can use curl -vk https://<serverip>/state.txt --> it gives the right response,
If i do the same with the vip, i get the following error, curl -vk https://<VIPip>/state.txt --> Below error
> GET /state.txt HTTP/1.1
> Host: xxxxxxxxxxxxxxx
> User-Agent: curl/7.47.1
> Accept: */*
* SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
* Closing connection 0
curl: (56) SSL read: error:00000000:lib(0):func(0):reason(0), errno 104
The server is local to the F5, directly connected,
Please let me know if there are any thoughts on this problem.
Lidev
April 28, 2020, 9:08am
2
Hello sathish,
I’ve already met this type of SSL errorno 104 when I was using an iRule containing errors with processing on the HTTP responses part.
Regards
Hi Lidev,
The Irule used on the vip is a standard rule which is used in 1000’s of other vip’s with no issues,
Do you see any other problem?
Lidev
April 28, 2020, 9:36am
4
It’s hard to say without more details about the virtual server and monitoring configuration.
I’ll still test without the iRule to see if you can reproduce the issue
Samir
April 28, 2020, 9:42am
5
Hope you have applied default “serverssl” profile to VIP and automap.. Apply and capture the packet. Hope it will work
Hi Samir,
Serverssl is applied, SNAT is not required as server is local to the F5, thank you.
Removing Irule didn’t help, anyway, thanks for looking into this
Are you able to ping the VIP?
Is this a production environment with real certificate/key attached to client SSL profile or you’re just testing it with default Client SSL profile? Do you have a client SSL Profile attached to the VIP? If so, disable “Generic Alert” option and you can follow the steps in this article to decrypt TLS traffic: https://devcentral.f5.com/s/articles/Decrypting-TLS-traffic-on-BIG-IP
Any findings? Having the same issue.
