HTTP2 only on client side
if http2 profile is enabled but pool member servers does not support http2, where as client browser does,
in that case will the client to load-balancer connection be http2 ? or it will also negotiate on http1.1 ?
if client side establish connection on http2, then would that give any performance benefits by only running http2 on client side ?
Q: in that case will the client to load-balancer connection be http2 ?
A: Yes, it will be HTTP/2
Q: if client side establish connection on http2, then would that give any performance benefits by only running http2 on client side?
A: The F5 supports HTTP/2 on both client and server side in v14.1.0 and later. There would certainly be performance gains to be had by just implementing clientside but perhaps not as pronounced as doing HTTP/2 full-proxy. If you were to say combine HTTP/2 on the client side with OneConnect then the clientside would benefit from the performance increase and the server-side would have a bit of a performance loss for the initial TCP handshake but proceed faster for future connections due to reuse.
Configuring HTTP/2 Full-proxy Support on the BIG-IP System
Thanks a lot Andrew
