I am familiar with the concept of deploying Microsoft TMG behind F5 LTM with forward proxy/reverse proxy. In that scenario I would use an iApp and follow the relevant deployment guides.
My question scenario is around HTTP URI filtering. I have a virtual server in front of a TMG gateway where I can filter the inbound connections by IP address (CLIENT_ACCEPTED event). I would like to filter (or reject) all inbound connection when a specific URI is requested from outside a few IPs (let’s say /clients/secured). This requires HTTP_REQUEST event, which requires an http profile.
I believe I have the iRule setup properly, however the browser just hangs as soon as an http profile is added to the TMG Gateway VS. It hangs without the iRule resource. * I have a custom http profile created that does not process or rechunk http (it is based upon http transparent profile) * I can provide a copy of the iRule in question. * I can describe the VS and edge network architecture if needed.
My questions: 1. Is it possible to place an http profile in front of a TMG gateway server for the solution I am attempting? 2. Should I pursue a different solution? 3. Will full TMG replacement with SWG / iApp provide what I need?
I have better bundle licensing so can leverage other modules outside of LTM if those are more appropriate. Looking to avoid full TMG replacement if possible. Thanks!
Thans Kunjan, if I understand correctly this means I should plan the TMG replacement to accomplish what I need. None of the other deployment scenarios or modules will accomplish the TMG URI filtering. Is that correct?
i never used tmg but you are talking about tmg as a reverse proxy, aren’t you? if yes, can you post the virtual server and pool configurations?
tmsh list ltm virtual (virtual server name)
tmsh list ltm pool (pool name)
kunjan, thanks for the suggestion. After setting up the TMG proxy pool and iRule code for HTTP_PROXY_REQUEST events I am getting “Secure Connection Failed”
