http to https redirection
Hi all
I need F5 Load balancer rule changes/procedure to redirect http traffic from one url ( https(https://xyz.com) another url
please let me know the step which need to be done for the same can be achieved.
You can use the following and just type the URL you need to redirect to
Example:
when HTTP_REQUEST { HTTP::redirect “https://[HTTP::host][HTTP::uri]” }
or
when HTTP_REQUEST { HTTP::redirect "; }
Also if the URI is the same as the original site you can just attach it at the end “https://xyz.com[HTTP::uri]”
I hope it helps! -Erika
