HTTP to HTTPS Redirection excluding specific HTTP URL
Hi - I have a requirement for following scenario;
Website configured on ASM : Default HTTP to HTTPS redirection;
http://www.abc.com > redirects > https://www.abc.com
Is it possible to redirect from HTTP to HTTPS and EXCLUDE URL from this redirect?
Hello Omar,
Try the following irule, if starting with “/xyz/ghq.asmx” it will not redirect, otherwise it will redirect to https.
    if { ! ( [string tolower [HTTP::uri]] starts_with "/xyz/ghq.asmx" ) } {
        HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri]
Hope it helps
Waiting for you feedback thanks
