http to https redirect with exceptions
Hello I am very new to iRules and just inherited a farm of 9.x F5.
I see that my predecessor is performing this task using the following iRule:
when HTTP_RESPONSE {
if { [HTTP::header Content-Type] starts_with “text/” }{
STREAM::expression “@http:@https:@”
STREAM::enable
STREAM::disable
I read about it and if I get it right this rules replaces everything that has the word HTTP with HTTPS?
The actual requirement I was given a few days ago is to replace links that contain HTTP with HTTPS if the link contains a specific word in it.
Can this be somehow achieved?
The same type of Irule can be applied. It all depends on what what you are looking to replace. IS the specific word part of a link?
Bhattman
Yes it is part of a link.
How do you implement it then?
Lets assume I want to rewrite everything that contains/not contains a certain string?
Then you should be able to do the following
 if { [HTTP::header Content-Type] starts_with "text/" }{
 STREAM::expression "@http:\\somedomain.com\word@https:\\someotherdomain.com\word@"
 STREAM::enable
 STREAM::disable
Bhattman
That iRule is using a stream profile to replace instances of http: with https: in text-type response content. If you need to make it more specific, you can possibly use a regex or the STREAM_MATCHED and STREAM::match command.
If you’d like more detailed suggestions can you post a few examples of links you do and don’t want rewritten?
Here are a few wiki pages with examples:
You might be able to tweak the find string of http: using a regex
http://devcentral.f5.com/Wiki/default.aspx/iRules/STREAM\_\_expression.html
Or you could use the existing stream expression, but then add logic to the STREAM_MATCHED event to only rewrite the specific matches you want to using STREAM::replace.
http://devcentral.f5.com/Wiki/default.aspx/iRules/STREAM\_MATCHED
http://devcentral.f5.com/Wiki/default.aspx/iRules/STREAM\_\_replace
Aaron
It would be nice to get to update the post from within an email.
CB
Thanks. I will test this.
