HTTP to HTTPS redirect over the same port
Hello,
i hope you can help me. I need an http to https redirect to the same port. For example I enter the URL http://dev.intern.com:25001 and I want to get redirected to https://dev.intern.com:25001. I tried a second virtual server but this didn’t work because the loadbalancer can’t have two the same IP and ports for a second server which redirects it with an irule to the https virtual Server which is understandable.
Thank you already and best regards!
Where are you terminating the SSL - on F5 or servers ?
I am not sure if you know this but you can have a set up like this: VS:80 VS:443
Both VS can then be attached to a common pool with pool members listening on port 25001 and you can have HTTP to HTTPS redirect iRule on VS:80
Hello,
we found the solution for the Problem. A few years ago a person had the same problem:
So you just have to use the iRule:
when CLIENT_ACCEPTED {
    set https 0
 when CLIENTSSL_HANDSHAKE {
    set https 1
    if {not ($https)}{
       HTTP::redirect https://[HTTP::host][HTTP::uri]
And to activate non-SSL in your SSL Profile under Local Traffic → Profiles → SSL → Client → (Profile you are using)
After that you are able to set the iRule on your SSL virtual server.
