HTTP:: request header insert issue
We’ve created an iRule to insert the username id into header for all HTTP requests.
Also have the rule logging this occurence. The issue we are seeing is that the username is
is NOT inserted into EVERY HTTP request. Note that we’ve had to create a session cookie to
support radius auth.
Note: 2nd entry has a blank client D value
Thu Feb 22 14:32:04 xxxx 2007 tmm tmm[984] 01220002 Rule rsa_cookie_radius HTTP_REQUEST: inserted Client id TEST_01
Thu Feb 22 14:32:14 xxxx 2007 tmm tmm[984] 01220002 Rule rsa_cookie_radius HTTP_REQUEST: inserted Client id
I am a real newbie when it comes to this stuff so some help would be great.
Here is the iRule
when CLIENT_ACCEPTED {
set authinsck 0
set forceauth 1
set ckname BIGXAUTH
set ckpass xxxxxxxx
set ckvalue [IP::client_addr]
set ckdomain .xx.xx.xx.xx
set asid [AUTH::start pam default_radius]
if {[HTTP::cookie exists $ckname]} {
if {[HTTP::cookie value $ckname] eq $ckvalue} {
set forceauth 0
log “HTTP_REQUEST set forceauth 0”
HTTP::cookie remove $ckname
if {$forceauth eq 1} {
AUTH::username_credential $asid [HTTP::username]
AUTH::password_credential $asid [HTTP::password]
AUTH::authenticate $asid
HTTP::collect
HTTP::header insert “X-EAU-Client-id” [HTTP::username]
log “inserted Client id [HTTP::username]”
when HTTP_RESPONSE {
if {$authinsck eq 1} {
HTTP::cookie insert name $ckname value $ckvalue path / domain $ckdomain
when AUTH_SUCCESS {
if {$asid eq [AUTH::last_event_session_id]} {
set authinsck 1
HTTP::release
when AUTH_FAILURE {
HTTP::respond 401 “WWW-Authenticate” “Basic realm=\”\“”
when AUTH_WANTCREDENTIAL {
when AUTH_ERROR {
HTTP::respond 401
cheers
m
