I have below iRule but it is not working as expected. two statement working /oncfo1/ and /oncres1/ but /use1/ not forwarding & also if no condition match then else statement also not giving result.
I want. if for particular source IP from internet and if access a host with three sub directories then redirect to accordingly but other then these sub directory, it should return content with some message.
when HTTP_REQUEST { set src_clint_ip [IP::client_addr] set host [string tolower [getfield [HTTP::host] “:” 1]] set path [string tolower [HTTP::path]]
log local0. “client=[IP::client_addr] host=[HTTP::host] path=$path”
if {( [IP::addr $src_clint_ip equals 176.202.126.81%1701] )} then { if { $path starts_with “/use1/” } then { HTTP::redirect “https://ecr.host.com.qa/use/” HTTP::respond 200 content “IP is $src_client_ip and /use1/” “Content-Type” “text/xml” } elseif { $path starts_with “/oncfo1/” } then { HTTP::redirect “https://ecr.host.com.qa/oncfo/” HTTP::respond 200 content “IP is $src_client_ip and /oncfo/” “Content-Type” “text/xml” } elseif { $path starts_with “/oncres1/” } then { HTTP::redirect https://ecr.host.com.qa/oncres/
HTTP::respond 200 content “IP is $src_client_ip and /oncres/” “Content-Type” “text/xml” } else { HTTP::respond 200 content “IP is $src_client_ip and not matching” “Content-Type” “text/xml” }
} else { HTTP::respond 200 content “IP is $src_client_ip and check it” “Content-Type” “text/xml” } unset src_clint_ip }
A few things to point out:
- You don’t need to set the src_client_ip variable because you’re only evaluating it once. The added variable just adds memory consumption. Truthfully, since you’re only evaluating the path 3 times, you could probably also skip setting the path variable as well.
- Is the %1701 a route domain identifier?
- In each of your conditions, you HTTP::redirect and HTTP::respond commands. The HTTP::redirect command issues a 302 response to the client with a Location header. The HTTP::response command, in this case, responds to the client with a 200 and some HTML content. These two commands are contradictory. If it works at all, it’s certainly an anomaly.
- I would add some logging to the top of your iRule to see what the path actually is. The fact that the “/use1/” condition isn’t catching would most likely indicate that the path is never “/use1/”.
Here’s a new version of your iRule. I made some assumptions about what you wanted to do in the conditions where you had a redirect and a respond.
log local0. "Client ([IP::client_addr]) is requesting: [HTTP::path]"
if { [IP::addr [IP::client_addr] equals 176.202.126.81%1701] } {
log local0. "Client IP match"
switch -glob [string tolower [HTTP::path]] {
"/use1/*" {
log local0. "Catch /use1/ - redirecting"
HTTP::redirect "https://ecr.host.com.qa/use/"
"/use/*" {
log local0. "Catch /use/"
HTTP::respond 200 content "IP is $src_client_ip and /use/" "Content-Type" "text/xml"
"/oncfo1/*" {
log local0. "Catch /oncf1/ - redirecting"
HTTP::redirect "https://ecr.host.com.qa/oncfo/"
"/oncfo/*" {
log local0. "Catch /oncfo"
HTTP::respond 200 content "IP is $src_client_ip and /oncfo/" "Content-Type" "text/xml"
"/oncres1/*" {
log local0. "Catch /oncres1/ - redirecting"
HTTP::redirect "https://ecr.host.com.qa/oncres/"
"/oncres/*" {
log local0. "Catch /oncres/"
HTTP::respond 200 content "IP is $src_client_ip and /oncres/" "Content-Type" "text/xml"
default {
log local0. "Default condition"
HTTP::respond 200 content "IP is $src_client_ip and check it" "Content-Type" "text/xml"
log local0. "Client IP doesn't match"
Thanks Kevin Stewart for the response.
I have used your content with little modification to observe the changes. and result of var log is as below.-- Just note… neither redirecting worked nore HTTP::response reflected in browser. Jul 10 16:11:57 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /oncfo2/ Jul 10 16:11:57 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 16:11:57 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch /oncfo Jul 10 16:13:02 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /abcd/ Jul 10 16:13:02 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 16:13:02 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Default condition Jul 10 16:14:53 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /pqrs/* Jul 10 16:14:53 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 16:14:53 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Default condition Jul 10 16:15:19 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /oncres2/ Jul 10 16:15:19 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 16:15:19 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch /oncres/ Jul 10 16:16:24 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /oncfo1/ Jul 10 16:16:24 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 16:16:24 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch /oncf1/ - redirecting
when HTTP_REQUEST { log local0. “Client ([IP::client_addr]) is requesting: [HTTP::path]”
if { [IP::addr [IP::client_addr] equals 176.203.127.247%1701] } {
"/use1/*" {
"/use2/*" {
HTTP::respond 200 content "IP is [IP::client_addr] and -use2-" "Content-Type" "text/xml"
"/oncfo1/*" {
"/oncfo2/*" {
HTTP::respond 200 content "IP is [IP::client_addr] and -oncfo2-" "Content-Type" "text/xml"
"/oncres1/*" {
"/oncres2/*" {
HTTP::respond 200 content "IP is [IP::client_addr] and -oncres2-" "Content-Type" "text/xml"
default {
HTTP::respond 200 content "IP is [IP::client_addr] and check it" "Content-Type" "text/xml"
Extent result. when using /use1/ Browser Result - The webpage cannot be found 404
when using /use2/ Browser Result - Blank, nothing displayed.
when using /oncfo2/ Browser Result - Blank Page, nothing displayed.
when using /oncfo1/ Browser Result - redirected to https://…/oncfo/… working.
when using /oncres2/ Browser Result - Blank Page, nothing displayed.
when using /oncres1/ Browser Result - redirected to https://…/oncres/…working. Error 403--Forbidden
Comments inline:
A request for /use1/ should result in a redirect to “https://ecr.host.com.qa/use/”, which (because there’s no condition for it) goes to the Default condition and should display some HTML content. Is this iRule applied to the “https://ecr.host.com.qa” URL? Does the “/use/” URI actually exist on this server?
Assuming you are still seeing the log message for the correct condition, the response you’re sending isn’t properly formatted as XML data. Your browser may be blocking it. If you try this from a cURL statement, you may see different results:
curl -k https://x.x.x.x/use2/
Same as above.
Same as above.
That’s certainly going to be an application issue.
and remaining test result of /var log and impact on browser.
Jul 10 17:11:25 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /a-b-c-d-e/ Jul 10 17:11:25 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 17:11:25 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : IP match but Default last condition
Browser - Blank Page, nothing displayed.
Jul 10 17:12:07 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (78.100.37.xx%1701) is requesting: /a-b-c-d-e/ Jul 10 17:12:07 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP doesn’t match
Browser - below output. The XML page cannot be displayed Invalid at the top level of the document. Error processing resource Line 1, Position 1 IP is 78.100.37.xx%1701 and check it ^
Jul 10 17:13:03 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (78.100.37.xx%1701) is requesting: /use2/ Jul 10 17:13:03 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP doesn’t match
Jul 10 17:13:29 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (78.100.37.%1701) is requesting: /use1/ Jul 10 17:13:29 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP doesn’t match
If you test all of this from the command line with cURL, you’ll be able to see everything more clearly, without the browser potentially thrashing the content.
curl -v -k https://x.x.x.x/a-b-c-d-e/
curl -v -k https://x.x.x.x/use1/
In any case, the payload you’re sending in the HTTP::respond is not properly formatted XML, so the browser is generating an error.
@Kevin, you correct that Browser not displaying the content. --So then How Can I make browser friendly response & XML no error .--
I tried in internet Explorer version 9. - showing Blank BUT when I tried from Mozila I got below response.
XML Parsing Error: syntax error Location: http://ecr.host.com.qa/use2/ Line Number 1, Column 1:IP is 176.203.127.247%1701 and -use2- ^
--Second Point when i tried /use1/ it should be redirected to /use/ but same problem that internet explorer no change in URL BAR however mozilla url bar redirection relfect but SML error.
When I try from Mozilla. Url bar changed to https://..use/.. and log below Jul 10 19:19:11 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 19:19:11 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 19:19:11 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting
-- When I try from Internet explorer. URL bar does not change to https://…but in logs below.
Jul 10 19:19:31 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 19:19:31 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 19:19:31 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting
BUT XML Example still a challenge coj not working.
This brings me back to an earlier question.
Is “https://ecr.host.com.qa” this VIP? The fact that you’re not getting the logs for “/use/” condition after the redirect suggests that the traffic is going somewhere else.
YES, http://ecr.host.com.qa & https://ecr.host.com.qa both are VIP. Basically I was not able to make iRule to reach HTTP request or Client accepted for SSL (https) thats why I am trying these for the http content and then forwarding to the https
by my final aim is to write iRule for https traffic and as per source IP and content in URI, I have to select the pool.
if you say the above statement then I tried the code below but still the same log.
switch -glob [string tolower [HTTP::path]] { “/use1/*” { log local0. “Catch-1 use1 to use - redirecting” HTTP::redirect “https://google.com/” }
and in mozilla I am being successfully forwarded to google.com
Jul 10 21:36:37 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 21:36:37 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 21:36:37 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting
Ah, so if I understood you correctly, this iRule was on the HTTP VIP but not the HTTPS VIP? If so, can you for testing change the “https://ecr.host.com.qa” redirects to “http://ecr.host.com.qa”. This should let you see the events for the “/use/” condition, and eliminate any of the confusion with potential SSL issues.
Also, just for testing, change the HTTP::respond to just send plain text (no text/xml Content-Type header):
one more thing when I used below it worked for internet explor also. HTTP::respond 200 content “IP is [IP::client_addr] and use2” “Content-Type” “text”
Sure. That leads me to believe it’s just an IE thing.
As I understood from above, you want me to create a iRule and associate it with https VIP ? or any simple way and then what to access in browser and where to see logs ? same at val/log/ltm ?
or simply you want the below to associate with HTTP VIP as it is “/use1/*” { log local0. “Catch-1 use1 to use - redirecting” HTTP::redirect “http://ecr.vodafone.com.qa/use/”
OR-- “/use1/*” { log local0. “Catch-1 use1 to use - redirecting” HTTP::redirect “http://ecr.vodafone.com.qa”
My suggestion is to do everything, for now, from the HTTP VIP. Change the redirects to reflect the HTTP VIP URL:
So that all traffic flows back to this same VIP.
YES made changes in existing above iRule that ..
below is the result when two test performed /use1/ and /use2/
for first test-1 >> /use1/ it is being redirected to / as per iRule .
Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: / Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:24:42 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : IP match but Default last condition Jul 10 22:25:20 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use2/ Jul 10 22:25:20 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:25:20 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-2 use2 - no redirect
Morover. result are different for ie & mozilla. see below first try from id then from mozilla
Jul 10 22:30:39 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /abcd/ Jul 10 22:30:39 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:30:39 tmm info tmm[7008]: Rule /DMS_Prod/test_i_Rule_ECR_2 : IP match but Default last condition Jul 10 22:30:51 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 22:30:51 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:30:51 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting
Jul 10 22:31:16 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /pqr/ Jul 10 22:31:16 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:31:16 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : IP match but Default last condition Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: /use1/ Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Catch-1 use1 to use - redirecting Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client (176.203.127.247%1701) is requesting: / Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : Client IP match Jul 10 22:31:23 tmm1 info tmm1[7009]: Rule /DMS_Prod/test_i_Rule_ECR_2 : IP match but Default last condition
correction from ie & mozilla.
