HTTP Referer
Dear Dev Team,
The iRule is working fine. But I want to get the requests to be forwarded to “Pool2” if the user who is coming from the subnet(9.3*) and the HTTP Referer value is “http://www.test.com/UK”
if {([HTTP::header exists “X-Forwarded-For”]) and ([string tolower [HTTP::uri]] equals “/maxi/homepage.do”)} {
switch -glob [HTTP::header values “X-Forwarded-For”] {
“9.23*” {
HTTP::redirect “http://www.test.com/MaXi/homePage.do?src=US”
return
“9.3*” {
HTTP::redirect “http://www.test.com/UK”
return
“9.102.*” {
return
elseif {[string tolower [HTTP::uri]] starts_with “/maxi”} {
pool Pool2
Could you pls suggest?
But I want to get the requests to be forwarded to “Pool2” if the user who is coming from the subnet(9.3*) and the HTTP Referer value is "http://www.test.com/UK"have you tried to add if-statement (to check referer) inside 9.3 switch case?
nope!
Could you pls suggest one?
