I have a requirement to check HTTP Referer headers and restrict it to base URL and anything else should be denied .
Example -- URL -- https://123test123.com Referer Header should be only https://123test123.com/* anything else denied
Can you suggest a iRule
set referer [string tolower [HTTP::header value "Referer"]]
Reject if Referer is not blank and does not start with https://123test123.com/
if {($referer != "") && !($referer starts_with "https://123test123.com/")} {
log local0.info "Rejecting request to [HTTP::uri] with Referer $referer"
reject
