HTTP Redirects
I am new to iRules and going through baptism by fire. I would like the following URLs: http://www.qa.ipcws.fiserv.com, http://qa.ipcws.fiserv.com, https://www.qa.ipcws.fiserv.com, https://qa.ipcws.fiserv.com to be redirected to Login - Client Workstation Any help would be greatly appreciated!
This is what I came up with so far…
if {[HTTP::host] matches “https://qa.ipcws.fiserv.com”}
HTTP::redirect “https://qa.ipcws.fiserv.com/cws.web/Login.aspx”
But I receive this error when attempting to save the iRule
01070151:3: Rule [qa.ipcws.fiserv.com-redirect] error:
line 2: [parse error: PARSE syntax 37 {syntax error in expression “[HTTP::host] matches “https://qa.ipcws.fiserv.com””: extra tokens at end of expression}] [{[HTTP::host] matches “https://qa.ipcws.fiserv.com”}]
line 2: [missing a script after “if”] []
I believe this did the trick for my VS listening on 443 when HTTP_REQUEST { if { [string tolower [HTTP::host]] equals “www.qa.ipcws.fiserv.com” } { HTTP::redirect “Login - Client Workstation” } if { [string tolower [HTTP::host]] equals “qa.ipcws.fiserv.com” } { HTTP::redirect “Login - Client Workstation” } } I then created a second VS listening on port 80 and configured this iRule when HTTP_REQUEST { if { [TCP::local_port] == 80 }{ HTTP::redirect “https://[getfield [HTTP::host] “:” 1][HTTP::uri]” } }
Upon further testing this does not work…Any help would be greatly appreciated!
Hi Eric,
If you want to redirect all of the HTTP requests to HTTPS preserving the URI, you can use the HTTP::redirect rule you posted. You could leave off the check for the port being 80 as all requests to the HTTP VS would be on port 80:
HTTP_REQUEST {
   HTTP::redirect "https://[getfield [HTTP::host] ":" 1][HTTP::uri]"
For the HTTPS VS, you can use an iRule like this to check the Host header value:
    Check the requested host set to lowercase
   switch [string tolower [HTTP::host]] {
      "www.qa.ipcws.fiserv.com" -
      "qa.ipcws.fiserv.com" {
          Matched the host check, send a 301 with the new location
         HTTP::respond 301 Location "https://qa.ipcws.fiserv.com/cws.web/Login.aspx"
      default {
          Take some default action?
Aaron
I removed the iRule from the HTTPS VS deleted the iRule, recreated the iRule with a different, and applied the iRule to the VS. However, the redirect is not working when I navigate to https://www.qa.ipcws.fiserv.com/. I am I missing any thing?
Thanks! I just tested the HTTP to HTTPS redirect and that is functioning…Still trying to get the redirect from www.qa.ipcws.fiserv.com to qa.ipcws.fiserv.com to work.
I just captured the traffic in Wireshark to determine if the Redirect was occurring. I did not see the redirect, but it could be due to the encrypted packets.
I am currently running version 9.4.8. I check to see if there were any known issues, but I could not find any.
Can you try using a browser plugin to view the unencrypted HTTP requests and responses? You can use HttpFox for Firefox or Fiddler for IE.
I think you’ll find that you’re getting a redirect loop because requests to any URI for https://qa.ipcws.fiserv.com are being redirected to https://qa.ipcws.fiserv.com/cws.web/Login.aspx. One way to fix this is by redirecting all requests for www.qa.ipcws.fiserv.com to qa.ipcws.fiserv.com and only requests for qa.ipcws.fiserv.com and / to the login page:
   log local0. "[IP::client_addr]:[TCP::client_port]: [HTTP::method] request to [HTTP::host][HTTP::uri]"
      "www.qa.ipcws.fiserv.com" {
         log local0. "[IP::client_addr]:[TCP::client_port]: Matched www.qa.ipcws.fiserv.com, redirecting to login page"
          Matched the host check, send a 301 with the new location for requests to /
 if {[HTTP::uri] eq "/"}{
            log local0. "[IP::client_addr]:[TCP::client_port]: Matched qa.ipcws.fiserv.com and /, redirecting to login page"
      default {
         log local0. "[IP::client_addr]:[TCP::client_port]: No match, doing nothing"
Aaron
So, it appears that the redirect is happening…but it is happening AFTER the SSL handshake. So users are presented the SSL certificate error and then if you click continue, the redirect occurs and the correct page is displayed. Is there a way to get the redirect to occur before the SSL handshake so the users are not presented with the SSL name mismatch?
Unfortunately, no there is no way to prevent this for two reasons.
1. You can’t modify encrypted traffic until it is decrypted, which won’t happen due to the SSL Mismatch (until you override it).
2. The iRule Processing Event Order has several events prior to HTTP_REQUEST event, which is what you are using.
RULE_INIT
CLIENT_ACCEPTED
CLIENTSSL_HANDSHAKE
CLIENTSSL_CLIENTCERT
HTTP_REQUEST
The best you are going to be able to do in this case is apply the Redirect iRule to the HTTPS Virtual Server and let the user be redirected after the SSL Certificate Mismatch Error.
Another way to do it would be to aim your @ record to a redirect Virtual Server that would do the “add www. and redirect to the www Virtual Server”, but you would have to get an SSL Certificate to apply to that Virtual Server, for your URL (without www) to prevent an SSL Certificate Error if the user access the HTTPS side of the URL.
