HTTP Redirect and cut out URL
client request contain url “mvpvote”,for example,request http://www.test.com/mvpvote/xxxxx,I want redirect URL to http://www.test.com:8080/xxxxx, I don’t how 。
if {[HTTP::uri] starts_with “/mvpvote”} {
pool Pool_Test.com:8080
So i would create a new pool that has the same servers but the port is 8080. I would redirect the requests to that pool. Also since i did not modify the full uri, you would need to change the path to content. (You would need to put it below mvpnote folder)
Regards
Regards
thanks ,But how to cut /mvpvote/xxxx to /xxxx
Try something like below one..
    if {[string tolower [HTTP::uri]] starts_with "/mvpvote"}{
        set newuri [string map -nocase {"/mvpvote" ""}[HTTP::uri]]
        HTTP::redirect "http://[HTTP::Host]:8080$newuri"
-Jinshu
Jinshu irule will work great but if you want the user to see the new url and add a redirect code then you might have to add a few things to it.
        HTTP::redirect "http://[HTTP::Host]$newuri"
As a quick solution, instead of cutting the url i would change the Path of content under iis or whatever web server you are using. I would add another folder named mvpvote
There are two drawbacks with the use of
string map
, in this case. Firstly, it will replaces all instances of “/mvpvote”, even if it happens more than once in the path (or if you’re using
HTTP::uri
, in the entire length of the Request Target). Secondly, it would replace, for example, “/mvpvote2/” with “2/”.
The following solution should be more correct, and as a bonus, better performing (though not tested!):
    switch -glob [HTTP::path] {
        "/mvpvote" {
            HTTP::respond 301 Location "http://[HTTP::host]/[HTTP::query]"
        "/mvpvote/*" {
            HTTP::respond 301 Location "http://[HTTP::host][substr [HTTP::uri] 8]"
string map
HTTP::uri
        "/mvpvote" {
        "/mvpvote/*" {
Yes,this is more exactly.thank you .I will test it.
