As this is probably an issue with the boundaries of the HTTP data, I’d guess that you’d need to use TCP commands to collect the payloads and try to inspect the HTTP headers and correlate that with the payloads. If it is possible, I’m guessing it wouldn’t be easy. A tcpdump would probably be the best option for troubleshooting the issue.
Maybe someone else has better ideas on this though…
