I’m getting this message:
tmm tmm[722]: 011f0005:3: http_process_state_header_xfer - Invalid action EV_SINK_HEADER during ST_HTTP_XFER_HEADERS
when I try to do a redirect (HTTP::redirect) in a LB_FAILED event. The messages appears everytime the redirect is executed. The redirection works consistanly on some (one) workstations and fails consistanly on others (5 so far).
What is this message trying to tell me.
Regards,
Bret
This is a known problem and will be fixed in the next release. In the mean time, you should be able to get around it this way.
when LB_FAILED {
HTTP::fallback "myhost.abc.com"
I tried HTTP:fallback and it seems to work fine.
Which release is the next release. I’m currently on version 9.1.1
Regards,
Bret
I am not sure what the release number is going to be right now but you should be able to track the change with support using CR50764.
